Subject: Re: Problem with MainStatus in C programm.
Hi Alexander,
MainStatus is a temporary object that is filled in with KFLOP info and uploaded to the Host PC. It shouldn't be accessed from KFLOP as KFLOP has all the information locally. We shouldn't have declared that. There is a global variable called ThreadActive that indicates which Threads are running. Use that value instead. See below:
extern volatile int ThreadActive; // one bit for each thread
Hi. Tom.
Tanks for advice.
I haveanother question.How can I stopa threadfroma с programon kflop.In the list offunctions isonlystart,pause and resumeto controlthreads.
Best regards, Alexander Kovylkin.
Group: DynoMotion
Message: 10697
Date: 12/20/2014
Hi Alexander,
Pause will work to kill a Thread. It is usually better to have Threads terminate themselves if possible. Killing a Thread unexpectedly runs the risk of leaving something partially completed if the Thread was last pre-empted in the middle of doing something.
Group: DynoMotion
Message: 10721
Date: 12/23/2014
Hi Alexander,
KMotionDef.h and PC-DSP.h header files list all the documented functions and variables for KFLOP. We only document things that we feel would be useful to User Programs.
VersionAndSize is a member of the temporary status structure (MAIN_STATUS) filled in and uploaded to the Host PC to inform the PC about what to expect regarding the status structure of the Version of firmware running in KFLOP. KFLOP already knows what version it is so I don't see a need for this. KFLOP also has random access to all status directly. So it wouldn't really make sense to package a status structure and send the status to itself.
ThreadActive was a special case where the same symbolic name referred to two different things in two different contexts. One was the global variable. The other was a member of the MAIN_STATUS Structure.
Group: DynoMotion
Message: 10722
Date: 12/23/2014
Hi, Tom.
Thank you for yourcomprehensive answer.I have anotherquestion.How can Ideterminefromaprogramon or offaxisat the moment?For example,If you turn offthe masteraxisMaksFollovingError,the slave axisremains active, which leadsto an overload ofthe servo.Perhapsit would be logicalthatwhen you turn offthe masteraxisand slavewould beswitched off,andvice-versa.
